Paid consult request
buildhouse
Member Posts: 18
Hi all.
I posted before asking where to start. I'm building a home in NJ, will have forced air, and I'm looking to add hydronic in the floor of the slab for extra comfort. I got some help, read the Uponor design manual, downloaded Loopcad, did a heat loss, made a design, and I was able to get pretty far! With all that I know that I'm for sure missing a lot.
I would love to review my plans with an experienced designer to see what I'm missing and how to make it better. I likely need a half hour zoom meeting as at this point I need to figure out pex placement, I'm pouring my slab in about a week, the rest of the details I can do later when I have more time.
(Uponor is 20 business days out for a design.)
Anyone to suggest who I can pay for a half hour consult on Zoom to review? I tried Borst Engineering but they only do full designs and are booked solid through April.
@buildhouse you can reach me at 20188788561
So I ended up speaking to @EzzyT and he was super helpful. Here is my layout and a drone shot right before we poured the slab (we are pouring the garage slab later). Could have been a but neater but hey, there's a first time for everything
Pressure held steady during the whole pour so it looks like we are ok.
I used PexB from supplyhouse.com as it was a lot cheaper, stapler from Amazon, hopefully wont regret my decisions.1 -
Are those unheated areas all cabinets? And the large unheated square left of middle? 18” spacing?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
You used an inferior product that’s encased in the concrete floor for the life of your house and you hope there won’t be any problems? I hope so too, but the laws of physics will outweigh the laws of economics every time.buildhouse said:So I ended up speaking to @EzzyT and he was super helpful. Here is my layout and a drone shot right before we poured the slab (we are pouring the garage slab later). Could have been a but neater but hey, there's a first time for everything
At the very least, the tubing should be isolated from the boiler and any ferrous components by a heat exchanger. That’s would also require a stainless steel circulator and an epoxy coated expansion tank on the floor side.
After adding those, what have you really saved?Bob Boan
I'm sure he used oxygen barrier pex-b.
Bluefin brand is manufactured by Rifeng.0 -
- 15.8K Strictly Steam
