Venting - What's code?
In Ireland, many of the houses' Sanitary waste & vent plumbing is on the outside of the house, especially since they can be a few hundred years old with thick Stone walls. Mad Dog 🐕1
I've seen that in Britain and Portugal as well as San Francisco...Mad Dog_2 said:In Ireland, many of the houses' Sanitary waste & vent plumbing is on the outside of the house, especially since they can be a few hundred years old with thick Stone walls. Mad Dog 🐕
So,
Regarding New Jersey Code I'm 99% sure I understand what's written but I'm not positive.
Best I can tell, if there's a vertical drop from a 2nd story to the 1st story, that's considered a drain stack and drain stacks must be vented full size. But, it seems like a 2 story "drain stack" is treated the same as a 10 story drain stack? Am I understanding this correctly? Where's a ranch house doesn't fall into this category and thus can be vented via multiple smaller vents that equal the required total venting.
But a 2nd floor bathroom automatically has to go full size?
Here's the scenario at hand. I apologize as this drawing isn't to scale and was rushed.
Anything I labeled wet means a sink or tub drains into it but isn't shown. To be specific, 1 1/2" on left side is 2nd story bathroom sink vent. 1 1/2" on right side is 2nd story tub vent. 2" vent is 1st story bathroom sink AND toilet vent. Not shown is the kitchen which ties in further downstream and has a 1 1/2" or 2" vent.
The question at hand is, as per NJ NSPC code, does that 8 foot tall "stack" to the 2nd story bathroom require a full size 3" vent (circled in red), or would a 2" be completely compliant? Due to framing etc, a 2" would be so much easier. The total amount of venting exceeds the requirement, but the fact that vertical connection goes to a 2nd floor is what's got me thinking it has to be 3".
This isn't about frost closure etc, in fact I can easily go to a 3" in the main attic. It's getting the pipe from the bathroom into the attic that is the rub.
Here's the code that's got me....
Bathroom groups that are not more than 1 story height. Does this mean 1st story, or 1 story height as in my 2nd floor bathroom? That 2nd floor is only 1 story height, no?
Here's the vent rule regarding drain stacks.
@Jamie Hall How do you interpret that code?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Assuming 1 story means literal height........
I have two 1.5" wet vents venting that "bathroom group" which according to code all it needs is a single 1.5" due to 3" pipe.
That means it's actually compliant without any additional venting and that's not technically a "drain stack".
If I remove that stack vent completely I'll still have a total of 1 two inch and three 1.5" vents which is a total cross sectional area of 8.5" or, more than a 3". It's actually totally compliant without any stack vent.
According to code.
I've got a headache.
@ChrisJ You can get an informal opinion from the New Jersey Code Assistance Unit. I've contacted them before. Once you get through the preliminary bureaucratic steps the fellow I talked to was quite friendly and helpful.1
I'm going to contact them.CLamb said:@ChrisJ You can get an informal opinion from the New Jersey Code Assistance Unit. I've contacted them before. Once you get through the preliminary bureaucratic steps the fellow I talked to was quite friendly and helpful.
Even if it wasn't a big pain in the butt to try and route a full size vent due to old framing, I actually want to know the real answer just for curiosity sake.
Add this for good measure.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I had someone local explain it to me and got it thru my thick head.
2 or more story heights means how many floors drain into it. In my case only one story.
I have a bad habit of overcomplicating things.
The good news is the only studor vent I have is going bye bye soon.
- 50 Industry Classes
