NYC-DEP tag looped with wire around water meter and pipes
$500 penalty, $1,000 default
when you get caught, whenever that may be.
break seal permits are free, but requires LMP
if dep responsible
https://portal.311.nyc.gov/servicerequest-create/What?caid=1ec98a85-fed2-e811-a970-000d3a1c50960 -
> what are the repercussions
You find similar seals on electric and gas meters. I know if I broke my electric meter seal I could wire *around* the meter for free electricity. The company does not like that, and has serious fines for offenders.
I assume dko's "LMP" is a Licensed Master Plumber. The company 'trusts' such people because if they do wrong their license can be yanked, their business ruined. The LMP will know how NOT to mess-up the metering. The break-seal permit probably also flags a follow-up so the next meter-reader takes an extra close look for wrong piping.
If the leak is on the *company* side of the meter, and not rotting your foundation, let it leak. If it is on your side of the meter, the excess water probably justifies calling a licensed plumber.0 -
If your talking about the GEC (grounding electrode conductor) that come from the main electrical panel (usually a #8,#6 or #4) depending on the service amperage you can remove that to fix leaks in the piping. I would recommend putting a jumper cable like you use to jump a car because in some areas you can have current running through the ground wire. Jump the inlet pie to the meter to the outlet pipe coming from the meter.
If you talking about wire seals on the meter you probably shouldn't touch those without permission0 -
No no...Only in a dire emergency and then, you must notify DEP at once so they can reinstall one. Mad Dog 🐕1
if the meter is leaking, isn't it the responsibility of the utility that owns the meter to repair it?
in any other city they'd just re-seal it when they found it 20 years later if it didn't look like you had cut it to bypass the meter but nyc might actually go after you.
Of course then there is the matter of how do they prove that it existed in the first place.1 -
There is a small drip from under the valve. What is that knob that petrudes?
This is the part: (it’s labeled Ford)
This is the entire setup, the valve on the left is the one with issue.
The drip is slow but I’m worried that it will get worse not better over time.
I think that is a plug type valve but i'm not sure how that particular one works. Ford is the manufacturer. Sometimes there is a spring and nut on the other side that holds the plug in but I don't see that there.0
Wire seals are cut ✂️ quite a bit on emergency repairs. As long as the Water Authority is notified, not a problem. Its funny but, Water Authorities are usually responsible from the street main to your curb valve at or around the curb. Bldg owner is responsible for service entering the bldg and the rest, EXCEPT the Water meter itself. Mad Dog 🐕1
Looking on Ford's web site those look like they are ball valves with some sort of synthetic rubber seats and o-rings for the seal for the shaft. Not terribly durable or repairable.0
- 117 Geothermal
