Two Pipe Crane Baseboard Valve
hrad
Member Posts: 55
My valve broke. I need to find another. Hopefully exact match so I can pull out stem and replace with new. From 1950's
Do you use it enough to warrant searching for a new valve or handle? Might be a tough find.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
It is heating season. The room gets too hot. The valves are 1/4 turn type. It now does not stop turning.
Can you stop turning it yourself? That is to say -- take it an eighth of a turn and see if it makes a difference. No change? try another eighth. There seem to be two possibilities -- the shaft broke above the stop in the valve body or the stop itself broke. It is likely that if you take it apart either one will be repairable by someone who is clever with a welder and grinder.Br. Jamie, osb
I only see a packing nut. If there's a bonnet nut below, there aren't any flats on it. It might be tough to take apart.
I found this, but don't know if it's the correct size for you:
https://www.ebay.com/itm/195381035627
Thank you! I will look at. Afraid to break taking apart and have no heat for awhile. Very hard to remove entire valve
That does look remarkably like. One has to wonder where eBay finds these things.I only see a packing nut. If there's a bonnet nut below, there aren't any flats on it. It might be tough to take apart.
I'd also say, though, three things: at that price, give it a shot. Second, it got put together, it has to come apart. And, unless you have to, don't mess with it until summer...Br. Jamie, osb
Or the seat screws in the bottom or something like that.
Do you need to change it or do you just need less heat? You could cover some of the baseboard element with foil to reduce the heat output, or is this cast iron baseboard? It looks like fintube with an old style cover or integrated cover.0 -
Thanks everyone. The shaft keeps turning around so I assume broken off. It is a cast iron two pipe baseboard that puts out too much heat when very cold out and boiler cycles a lot. I will wait till summer. Would be very hard to remove and replace valve.0
- 117 Geothermal
