Welding a Cracked Boiler
Silly question, but it crossed my mind.
Anyone ever hear of someone welding or repairing a cracked boiler?
I assume it's possible... right?
mattmia2Mad Dog_2
    mattmia2 Member Posts: 13,276
    Sometimes with commercial steel boilers. Not usually practical on small cast iron boilers.
    Hot_n_ColdIronmanMad Dog_2
    Jamie Hall Member Posts: 26,124
    Welding cast iron is astonishingly difficult to do, particularly if there is much of it. Not usually worth it.
    Hot_n_ColdIronmanMikeAmann
  • Ironman
    Ironman Member Posts: 7,724
    It’s also against code on a residential boiler as it voids the ASME certification.
    Bob Boan
    mattmia2Mad Dog_2kcopp
  • Daveinscranton
    Daveinscranton Member Posts: 148
    Yes.
    My dad was a welder in WWII in the 757th Railroad Shop Battalion.  His commanding officer asked him to weld a boiler for a French school/orphanage at the tail end of WWII prior to the invasion of Germany.  There was no choice.  Nothing was available.  Wartime.
    He said the boiler was toast.  Goodwill type of thing done by the Army.  He had one drip.  Just as he was about to peen the drip, his Captain had hammer in hand and tapped the braze, one expert blow to seal it.
    He hated doing it as he knew the boiler was essentially Swiss cheese and paper thin.  But there was zero choice.
    He would not encourage you (or anyone) to try if he were alive today.
    mattmia2Mad Dog_2PC7060
  • realliveplumber
    realliveplumber Member Posts: 354
    edited February 2024
    Brazing cast iron is a different process than welding it.
    To weld cast iron you need need to pre heat and post heat it. Not practical for a boiler in situ.
    Mad Dog_2ChrisJ
  • Big Ed_4
    Big Ed_4 Member Posts: 3,232
    They would pound in lead :)
    delcrossvMad Dog_2Daveinscranton
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,255
    Steel wool & Sal ammoniac...iron filings....aka A Rust Joint.  Mad Dog 🐕
    realliveplumberDaveinscranton
  • guzzinerd
    guzzinerd Member Posts: 335
    MikeAmann said:
    No pictures posted, but what about JB Weld High Temp - either the epoxy syringe or the putty? https://www.jbweld.com/product/high-heat-syringe https://www.jbweld.com/product/highheat-epoxy-putty
    I've had far better results from Marine Rx (West Marine) than jbweld.  The stuff is amazing.  oil, gas, etc proof.
    https://www.westmarine.com/travaco-marine-tex-epoxy-putty-repair-kit-white-P004_120_005_502.html
    Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
