Fish House in Berkeley
Member Posts: 4,736
greatI was here yesterday flushing air out of the radiant (polybutylene). It's pretty wild and very well done.
Name
The owner built it for his parents in the mid-1990's. His grandchildren now live there.
https://en.wikipedia.org/wiki/Ojo_del_Sol
Two btu per sq ft for degree difference for a slab1 -
How has the PB held up over the years? Is it PBX or not.....O2 barrier?0
if they run extremely low temperature the non barrier might not be a huge issue. It would be too bad if the pb failed, reading about this house the architect designed it after the tardigrade, and was meant to be " the safest house in the world," intended to survive fires, earthquakes, flooding, and termites". so hopefully it survives the pb tubing as well0
The non- barrier polybutylene has held up very well - no issues. Radiant heating is only in the lower floor which is about 500 square feet and the heat source is a domestic water heater; stainless steel pump. A marriage made in heaven. Oxygen intrusion? No problem.The neighborhood has mostly small, working class homes that go at a premium because of their proximity to the Fish House. It’s considered good luck.A previous tenant was a group of start-up entrepreneurs that claimed that all their most brilliant ideas came to them while living here.Have you ever been to Sedona, Arizona and experienced standing in a vortex? Being in the Fish House reminded me of that feeling. Safe, secure, inspired ……8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
- 120 Geothermal
- 396 Solar
