Converting from hydronic wall heater to standard electric heater
Antbro
Member Posts: 7
I have 4 hydronic wall heaters throughout the house. The first one to need to be replaced has happened and I am wondering if rather than paying an arm and a leg to replace it with another hydronic, if it is possible to cap it off and put in a less expensive electric wall heater. As they stop working it will be very expensive for me to replace them. Thoughts?
As always with this type of decision -- check the actual cost of energy. You will use roughly the same amount of energy either way, as measured by BTUh, but depending on where you live and your fuel and electric power costs, whether you save money -- or spend as much as four times as much -- depends on your costs.Br. Jamie, osb
Depends on your electric rate. Mine is 22c KWh. It is adjusted every six months . Last winter it was 36c kWh . I would have been in poorhouse last winter if I was heating with electric resistive heat.0
I don’t see how it would be cheaper to install an electric heater considering that you would have to add a 240v circuit, thermostat, etc.
If the piping arrangement is a series loop, then it can’t be just “capped off”. The same would apply to a Monoflo system.
By the time you pay someone to drain the system, re-pipe it, fill and purge it, how is that any cheaper than replacing the baseboard?
Then, you would have the expensive of installing the electric on top of that.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
Are these fain coil wall heaters?
What is failing on the hydronic units. Every part inside is replaceable, coil, motor, thermostats, etcBob "hot rod" Rohr
We have 4 different guesses here about what you mean by "hydronic wall heater". can you post some pictures, preferably both outside and inside of what device you are referring to.0
(edited)Thanks for all the input.
This is a townhouse and is the middle unit, so the place stays warmer than usual year round so it isn't even really needed to be used in the room it is in. The new tenant saw that it wasn't working. I'm just looking for a cheaper option than replacing the current heater.
The fan motor stopped working. Had a plumber say it we couldn't get individual parts to replace.0 -
Here is the unit - https://www.designheating.com/catalog/Product_detail.cfm?ProductID=2902630
What exactly is broken on that Wall heater? the fan motor? the aquastat? the coil leaks? or something else? those parts are all replaceable, the most expensive part will be the coil leaking, because that will involve draining the system to the bottom of the wall unit. Any other part is an easy fix. here is a place where you can get the parts online Turbonics Parts
Depending on your location and suppliers in your area, you may find that Beacon Morris is the same product.Edward Young Retired
Here is what the plumber said they were going to do:Preferred Plus Blower Motor RepairRemove and dispose of existing componentInstall new blower motor on existing mountsMotor capacitor renovationIgnition system serviceFlame rectification system renovationRestore system to clean condition1 year warranty
I have looked on turbonics and Boston (Beacon) websites and it doesn't appear they have parts for this discontinued product.0 -
Antbro said:Here is what the plumber said they were going to do:Preferred Plus Blower Motor RepairRemove and dispose of existing componentInstall new blower motor on existing mountsMotor capacitor renovationIgnition system serviceFlame rectification system renovationRestore system to clean condition1 year warranty
“Capacitor renavation” There’s no such thing. A capacitor is a factory sealed part that can only be replaced and should be when a new motor is installed.
“ Ignition system service”. I thought this was a hydronic unit? There’s no combustion or ignition in it, just hot water.
”Flame rectification system renovation”. Flame rectification is part of the flame safety system on a gas burner. There’s no gas burner in that unit.Bob Boan
All for $, I figured as much. Going to keep digging but finding replacement parts looks grim.
Sounds more like a boiler repair bid, not the heater unit? There is no ignition or flame rectification in the Turbonic.Bob "hot rod" Rohr
I believe that this product will fit inside the housing your Turbonics cabinet that is currently in the wall. https://s3.amazonaws.com/s3.supplyhouse.com/product_files/Beacon-Morris-K42-Submittal-Sheet.pdf
If it can not be modified to fit, there are cabinets that can replace the cabinet you have. https://www.supplyhouse.com/Beacon-Morris-W42-W42-Recessed-Cabinet-Kit-9763000-p
I must be getting OLD. I remember selling the Turbonics when I worked at Weinstein Supply.
You can find a new motor here
https://designheating.com/catalog/subcat.cfm?Category=138&SubCat=590
They're between 60 and 80 bucks.
Flame rectification of a kickspace heater. That's a good one.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
Thanks! I will call turbonics on Monday and get clarification as to which of these will work with it.
you need someone competent to figure out what is wrong with it first. it could be that the thermostat isn't calling for heat or there is no 24vac power or the zone valve is bad so that the coil isn't heating and causing the blower to come on or the aquastat is bad too.0
@Antbro , we do NOT discuss pricing on this forum. You need to edit out the pricing. Now.Antbro said:All for $XXXX, I figured as much. Going to keep digging but finding replacement parts looks grim.
See:
https://heatinghelp.com/forum-user-manualAll Steamed Up, Inc.
Consulting1 -
@Antbro
Call Turbonics and get the straight scoop. If they don't have parts ask them if they have a replacement unit with the same or similar dimensions.0 -
Let's start with is the coil getting hot when there is a heat call. It could be a problem with the hydronic system rather than the unit heater.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 989 Plumbing
- 389 Solar
