Need help or options
There is always someone to do a job for the right price.
Unless you are looking to educate yourselves, learn, and DIY (depending on the issue), you will be hiring someone regardless. Maybe it's just a dead battery in a thermostat.
You can start by actually describing the problems in detail. What exactly doesn't work, how it doesn't work, how it worked before, etc.. Use photos, take pictures of the boiler and radiators.
No one can help you with just what you posted.
AndreousRose said:
I have a two-story house with a boiler heater system that is broken not sure if the radiators are good would like to know if it's possible to put in a furnace I know that I only have a crawl space however there is a Breezeway where the boiler system is and that a furnace could be put and either case I'm having issues finding someone to help Finance or even be able to get this done I have gone most of the winter without heat I have already had my water pipes burst and I'm having to fix it on our own this is our first house our first experience with any of this I need help I need advice I need something.
A furnace is going to take up more room because appropriate ductwork is always going to be much much larger than piping you need for radiators.
First I'd want to know if the radiators and piping are damaged or not and if they are how much to repair it. If there's a lot of damage start looking around to see where large ducts could be run.
Another option you may want to consider is mini splits as they need small piping, but they also need to be placed appropriately to run the piping as well as distribute the heating / cooling to the locations you need it.
Can you share some pictures of a few of the radiators, as well as good pictures of the boiler and piping around it?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I would stay with the boiler.AndreousRose said:I have a two-story house with a boiler heater system that is broken not sure if the radiators are good would like to know if it's possible to put in a furnace I know that I only have a crawl space however there is a Breezeway where the boiler system is and that a furnace could be put and either case I'm having issues finding someone to help Finance or even be able to get this done I have gone most of the winter without heat I have already had my water pipes burst and I'm having to fix it on our own this is our first house our first experience with any of this I need help I need advice I need something.
With that said where is this home?0
- 50 Industry Classes
