How to ream pipe over 4"?
It's odd Ridge offers a 6" threader but no way to ream the pipe in that size. Did/does someone make a 6" reamer?
For pipe over four inch:
For steel we grind the outside. The inside we grind or use a file as suggested above.
For CPVC or PVC we use a file for the outside and the inside.
For copper we use a file for the outside and the inside, then follow up outside with sand cloth.
EDIT: I apologize, I just realized you probably only referring to steel pipe that you are preparing for treading. I assume a file might suffice. We have never threaded pipe over four inch. We always weld or purchase premade nipples on any steel pipe over four inch.2 -
There's this type of tool too.
https://www.milwaukeetool.com/Products/48-22-4255
I'd probably go with a die grinder if I were doing a lot of it.0 -
That would take forever on iron pipe. Die grinder sounds plausible.mattmia2 said:There's this type of tool too.
So, did reamers always top out at 4" ? I did see one on ebay that goes on a powerhead (?)Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
We have and still occasionally use the Milwaukee reamer that @mattman_2 linked. It works great on copper, but I doubt is could be used on steel.
As far as reaming tools that are designed for reaming streel pipe larger than four inch, I bet there is something out there. There is no way that every five or six inch nipple we see was reamed by hand with a file. Same holds true for the hundreds of twenty one foot lengths we have purchased over the years. Perhaps they use a lathe of some sort?0 -
The Oster 8R can thread up to 8". It comes with its own reamer.
https://www.ostermfg.com/thread-machines/oster-8r
Standard Equipment Furnished
Motor - 7.5hp., 1200 rpm., 3 phase, 60 Hz. 230 or 460 volts. (Motors of other specifications available.)
Motor Control - REVERSING magnetic starter and push button station, with safety 120V control circuit at machine controls.
Dieheads - ONE, radial, quick-opening type, adjustable to handle all sizes in standard range.
Die Holders - ONE set to cover standard pipe range.
Dies - ONE set to cover standard pipe range - 2-1/2" to 8", HIGH SPEED STEEL (Symbol 8R).
Reamer - Swing-type.
2 -
I suspect there isn't a lot of field threading of stuff over 4" going on, most probably is cut with a saw or grinder that doesn't leave much of a burr and joined with other methods.0
Man! I hate to try to move that to a jobsite. 😲 Maybe call lengths back to the shop?WMno57 said:The Oster 8R can thread up to 8". It comes with its own reamer.
Someone has to make a 6" portable reamer.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
I think a welder would be much easier to move to the job. I'd imagine one would only bring that on site for something like a high rise or refinery project.0
Maybe this is portable enough to get to the jobsite
No threading or reaming required.Edward Young Retired
Fair enough, but that still doesn't solve the initial question (except by filling or grinding). No one makes a 6' reamer that fits in , for example, a Ridgid 300?mattmia2 said:I think a welder would be much easier to move to the job. I'd imagine one would only bring that on site for something like a high rise or refinery project.
This machine has a reamer built in... it handles up to 6" pipe
https://www.wheelerrex.com/products/threading-and-grooving/pipe-threading-machines/6-inch-pipe-threading-machines/Edward Young Retired
That's the point, they make a 6" threader, but not corresponding reamer.dko said:Threading machines with 6"+ threading capability will have their own reamer assembly that's part of the machine. If using a geared threader attachment to a smaller threading machine like a Ridgid 300, you'd use manual methods suggested above.
Imagine holding up and ratcheting a 6" reamer..
Woo Hoo! Now we're cooking with gas! 2" to 6"! And it's portable! 😍EdTheHeaterMan said:This machine has a reamer built in... it handles up to 6" pipe
Thanks Ed.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
These work best in a high speed die grinder, I recently bought a Milwaukee cordless die grinder., very handy.
They will work in cordless drills also, but slowerBob "hot rod" Rohr
Living the hydronic dream1 -
Still strange they'd offer a hand geared threader but not the corresponding reamerTrying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
Cut the pipe with a bandsaw. Then there is hardly a burr to remove.0
A die grinder ....
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
