8 way separated
Neild5
Member Posts: 203
I use 8 way in my boiler, at about a third of the concentration recommended on the bottle, I add till the pH is 11. When the boiler is running there is a band of clear water in the sight glass, 5-10 minutes after the boiler stops it is back to a homogeneous solution. I don't see it is a problem, but think it is weird.
That is interesting but you sure have clean water. Keep it up
Blow down the sight glass & see if the clear water comes back.0
Hello @Neild5,
Is the clear liquid at the top of the sight glass actually condensate from the steam entering from the top port of the sight glass assembly ? When the steam stops the new (chemical free) condensate stops. During idle periods it all goes back into an equal mixture.
One Pipe System4 -
I hadn't thought about that, but it makes sense. It was the first time I have seen it do that.109A_5 said:Hello @Neild5, Is the clear liquid at the top of the sight glass actually condensate from the steam entering from the top port of the sight glass assembly ? When the steam stops the new (chemical free) condensate stops. During idle periods it all goes back into an equal mixture.0
- 15.8K Strictly Steam
