"Removing a Pressuretrol" revisited
https://www.youtube.com/watch?v=57p64_py5QYThe Pressuretrol in the video is a different model than the one in the thread photos. I have one that looks like the one in the video. Should I, or should I not, remove it that way? I'm planning to put on a T and a low pressure gauge for now, and a Vaporstat later.
Thanks.
My question is, why do you want to take it apart? If you need to take it off, just unscrew it from the pipe. The wiring should be much easier to deal with than taking the device apart.0
I'm not certain yet, but I may have the same problem as in the original thread I linked to.KC_Jones said:My question is, why do you want to take it apart? If you need to take it off, just unscrew it from the pipe. The wiring should be much easier to deal with than taking the device apart.
I have installed several steam boilers and have repaired several others. I don't believe that I ever had an occasion where you could not get the pressure control off to inspect the pigtail. Sometimes I needed to turn the pigtail to a different position so the control was at the edge of the boiler, or turned away from the LWCO, but there was always a way. If I did find it difficult, then I would add a fitting or two to make it easy to inspect the pigtail the next time. Pigtails need to be inspected regularly, so why not make it easy.
2 -
I have the PA404A model pressurertols (the same as in the thread) on my two boilers. On more than one occasion, I've removed the screws in the bottom to disassemble. (Before I added unions.)
It really isn't a big deal. You just have to be careful not to lose the screws, and to understand where they and the other parts go inside the box. It makes it much easier to put the screws back in if you lower the pressure settings as much as possible so there is minimal force on the mechanism.
I have never done it on the type of pressuretrol in the video so can't speak to that one specifically. I assume it isn't much different.0 -
What are you trying to avoid, Removing two wires ? I will say once you dissemble a limit , your name is on it ... Food for thought .
No, I just thought I might not have enough room to unscrew it from the pigtail, or to unscrew the pigtail itself (similar to the problem demonstrated in the video). But on closer look I do think there's enough room. I'll find out once I get all the fittings I need to add the low pressure gauge.Big Ed_4 said:What are you trying to avoid, Removing two wires ? I will say once you dissemble a limit , your name is on it ... Food for thought .
And Ed the heater man says the same thing.Big Ed_4 said:What are you trying to avoid, Removing two wires ? I will say once you dissemble a limit , your name is on it ... Food for thought .
What are you trying to avoid, Removing air from the tires ? I will say once you remove the lug nuts , your name is on it ... Food for thought .
What are you trying to avoid, washing your underwear ? I will say once you open the package of briefs, your name is on it. if your mother has a needle and thread. ... Food for thought .Edward Young Retired
Exactly, as shown in the video.EBEBRATT-Ed said:Because sometimes the pressure control is installed and it is too close to the boiler jacket to spin and another control like a low water cutoff is installed next to it which prevents the pressure control assembly from being spun off.
I'd rather cut a pigtail in half to remove it than try my luck reassembling a pressure control. And I love to take things apart and put them back together. But not pressuretrols.
It may have seen it on YouTube but it's not correct practice . No safety should be repaired ,only replaced . Ask me how I know that ...
If it was installed on the boiler it can be removed . I know package units come with the tight pressure control . The pigtail and control were spun on together . Something still in the way ? It can also be cut out and extended . You can add a tee for service at that time.. Work safe out there ..
Hello @wilder0m,
Why would you want to further compromise a typically poorly calibrated device ? With a PA404A that diagram extension can move around and it can change the calibration.
If you can verify the calibration after (as the author of the video states) it is probably doable. If you can't verify the calibration and proper operation I would not do it.
One Pipe System0
- 50 Industry Classes
