How to tell if old flue is asbestos?
It may well contain asbestos. Only way to be sure is to have it tested by a certified person.Br. Jamie, osb
Transite cement/ asbestos. Was approved back in the day. Should be replaced with modern type B-vent or convert appliances to power vent but still remove. Agree w/ Jamie have it tested. If positive, contract with certified asbestos abatement contractor to do it right so there is no impediment on the title of the property or that anyone is huffing it. Worst thing you can do to asbestos is disturb it. If you must disturb it, be trained, qualified and equipped to do it.0
The only way to know is to have it tested by a certified lab.0
The heat resistant paper wired onto the vent pipe at the bottom of the photo also probably contains asbestos.—
Bburd0 -
I think the only "high temp light weight concrete" is asbestos cement, also known as Transite as stated above.
That looks like asbestos paper or aircell around that other vent as well unless it is a transite pipe in to a steel ell.
In any case it should be tested but I think everyone here would be shocked if any of it isn't asbestos.0 -
Wow , I never seen that type of vent . What part of the Country was that system used ?
This is in the S.F. Bay AreaBig Ed_4 said:Wow , I never seen that type of vent . What part of the Country was that system used ?
About half the people that have come out to give me bids on replacing the equipment/flue has mentioned the asbestos concern and the other half have made no mention of it. It's kind of surprising to me that so many don't know or care. These are all reputable radiant heating companies.0
I am thinking it looks small in size , maybe originally vent for a Kelly Pot which is an oil dripper . What fuel do you have access to ?
Looks like Asbestos-Cement pipe. ONLY way to know is lab test with Electron Microscope. Assume it is...Mad Dog 🐕0
The good thing about AC is that its not usually Friable, so removal is very quick and easy. Mad Dog 🐕0
Natural gas. You can see the boiler here, which is likely original to when the house was built:Big Ed_4 said:I am thinking it looks small in size , maybe originally vent for a Kelly Pot which is an oil dripper . What fuel do you have access to ?
Yep , Look into a wall hung Combe . Do you have a good outside wall or do you have to send the vent up through the old ?
is that a 120v gas valve? was the baso switch a retrofit?
did someone pull out the boiler and put it back to replace the water heater? you want to fix that with the new install.0 -
Yeah, I'm looking into a combi boiler given the space constraints and minimal domestic hot water needs. It would be awkward to try to route the vent somewhere other than through the existing roof vent.Big Ed_4 said:Yep , Look into a wall hung Combe . Do you have a good outside wall or do you have to send the vent up through the old ?
I'm not sure about the 120v gas valve and also not sure if that baso switch was original.mattmia2 said:is that a 120v gas valve? was the baso switch a retrofit?
I had to replace the water heater heater about 15 years ago and the boiler needed to come out to do it. I also had a gas leak behind the water heater about 8 years ago that required both the boiler and water heater to come out. My plan was to replace everything in the closet with a combi boiler so that all parts will be easily serviceable going forward.0 -
I'm thinking a taste test is out of the question.
In California... I remember doing some taste testing a few years back.
But that may have been at a WineryEdward Young Retired
- 117 Geothermal
