Cool little tool for verifying circ pump rotation ?
Watched a tech whip out a small keyfob looking tool and held it against the end of a circ pump. The little bar on the tool spun around (like a compass needle spinning), so he knew the pump was currently operating.
Such a simple and useful thing.
Everyone has one of these I guess ?
  • hilltown
    hilltown Member Posts: 76
    Grundfos MRI Run Indicator Magnetic Rotation Instrument Key
    hot_rod Member Posts: 26,810
    But don’t be fooled, it may be spinning and the pump is not. It reads the electromagnetic force being present. It does not work on all brands of pumps, or on ECM type.
    It will also spin when pressed against some solenoid valves. That are not rotating.
    GroundUp
  • Dave Carpentier
    Dave Carpentier Member Posts: 635
    Just like that. Not sure if it was Grundfos.
    If I can find my compass around here somewhere, I'm gonna see if that works.
    Many different companies used them for giveaways. Get one at Amazon, and here is the manufacturer
  • The Danfoss magnetic tool app. is probably just as reliable.
    Zmanheathead
    But still not a proof of rotation
    pecmsg Member Posts: 6,827
    I've seen as many False readings as positive. It shows Voltage present not that its turning!
  • STEVEusaPA
    You can get the same basic info from just clamping your meter onto it.
    pecmsg
    or a voltmeter
