How to tell if old flue is asbestos?
ThinkpadUser7
ThinkpadUser7 Member Posts: 137
edited January 2024 in Chimneys & Flues
This is the flue that connects to my hot water heater and boiler for the radiant heating. The house was built in 1947. I'm currently pursuing having all the equipment in this closet replaced but I'm not sure how to tell if the flue is asbsetos or just an "old vent that’s made of high temp. light weight concrete" as one person called it. I don't really want to touch it. Short of hiring someone to test it, is there any way to tell?
    Jamie Hall Member Posts: 27,367
    It may well contain asbestos. Only way to be sure is to have it tested by a certified person.
    Intplm.
  • Bob Harper
    Bob Harper Member Posts: 1,162
    Transite cement/ asbestos. Was approved back in the day. Should be replaced with modern type B-vent or convert appliances to power vent but still remove. Agree w/ Jamie have it tested. If positive, contract with certified asbestos abatement contractor to do it right so there is no impediment on the title of the property or that anyone is huffing it. Worst thing you can do to asbestos is disturb it. If you must disturb it, be trained, qualified and equipped to do it.
    pecmsg Member Posts: 7,064
    The only way to know is to have it tested by a certified lab.
    Intplm.
  • bburd
    bburd Member Posts: 1,303
    The heat resistant paper wired onto the vent pipe at the bottom of the photo also probably contains asbestos.
    Bburd
    mattmia2 Member Posts: 16,762
    edited January 2024
    I think the only "high temp light weight concrete" is asbestos cement, also known as Transite as stated above.
    That looks like asbestos paper or aircell around that other vent as well unless it is a transite pipe in to a steel ell.
    In any case it should be tested but I think everyone here would be shocked if any of it isn't asbestos.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    Wow , I never seen that type of vent . What part of the Country was that system used ?
  • ThinkpadUser7
    This is in the S.F. Bay Area
  • ThinkpadUser7
    About half the people that have come out to give me bids on replacing the equipment/flue has mentioned the asbestos concern and the other half have made no mention of it. It's kind of surprising to me that so many don't know or care. These are all reputable radiant heating companies.
  • Big Ed_4
    edited February 2024
    I am thinking it looks small in size , maybe originally vent for a Kelly Pot which is an oil dripper . What fuel do you have access to ?
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,547
    Looks like Asbestos-Cement pipe. ONLY way to know is lab test with Electron Microscope.  Assume it is...Mad Dog 🐕
  • Mad Dog_2
    The good thing about AC is that its not usually Friable, so removal is very quick and easy. Mad Dog 🐕
  • ThinkpadUser7
    Natural gas. You can see the boiler here, which is likely original to when the house was built:
  • Big Ed_4
    Yep , Look into a wall hung Combe . Do you have a good outside wall or do you have to send the vent up through the old ?
    is that a 120v gas valve? was the baso switch a retrofit?
    did someone pull out the boiler and put it back to replace the water heater? you want to fix that with the new install.
  • ThinkpadUser7
    Yeah, I'm looking into a combi boiler given the space constraints and minimal domestic hot water needs. It would be awkward to try to route the vent somewhere other than through the existing roof vent.
  • ThinkpadUser7
    I'm not sure about the 120v gas valve and also not sure if that baso switch was original.
    I had to replace the water heater heater about 15 years ago and the boiler needed to come out to do it. I also had a gas leak behind the water heater about 8 years ago that required both the boiler and water heater to come out. My plan was to replace everything in the closet with a combi boiler so that all parts will be easily serviceable going forward.
    EdTheHeaterMan Member Posts: 12,172
    I'm thinking a taste test is out of the question.
    In California... I remember doing some taste testing a few years back.
    But that may have been at a Winery
    Intplm.
  • Anija94
    Anija94 Member Posts: 1
    If the flue looks like a cement pipe with a slightly rough, gray surface, it could be transite, which often contained asbestos.
    The safest move is to get a small sample tested by a certified lab…it’s cheap and takes the guesswork out. Anyone else here run into transite flues during boiler or water heater updates?
  • Mad Dog_2
    The ONLY fool-proof method: Electron Microscope . Mad Dog
    pecmsg
    we've been talking about the asbestos above the ceiling in one of our auditoria for 20 years.
