Buderus Logano G115 Oil Boiler issue
Lutz
Member Posts: 4
in Oil Heating
Hello, I recently purchased a new Buderus Logano G115 Oil Boiler and have a concern. It starts and runs for 2 minutes, then it shuts off, and then 10 minutes later it kicks in again and only runs for another 2 minutes. This is how it operates throughout an hour. This does not seem to be correct?
The technician that installed the heater also installed a new thermostat, so my assumption is that they would have installed the correct type of thermostat.0
How does it heat the home ?
Good, the house is warm.0
Thank you all for the comments.
The boiler model is G115 WS/4.
We're still learning it and not sure how to get the settings.0 -
Did the installer perform a heat loss calculation prior to the install? Unless you have a huge house, lots of windows, lack of insulation, or live in an extremely cold environment the boiler is probably oversized. Depending on the controls you have you could try to increase the high differential to increase the run time.0
