Boiler Tripping
joe143
joe143 Member Posts: 25
Hello Folks- Wondering if anyone would know why boiler trips when oil tank goes below Half. I would need to bleed it to restart.
    mattmia2 Member Posts: 16,800
    air leak somewhere
    joe143
    EBEBRATT-Ed Member Posts: 20,180
    Don't know what kind of set up you have I am assuming and indoor tank. If the oil level in the tank is above the burner pump you have gravity feed. If the oil level is below the pump you have a suction lift feed.
    With suction lift every fitting has to be absolutely airtight or it will suck in a little air and the pump will lose it's prime.
    joe143
  • CTETeach
    CTETeach Member Posts: 33
    Does the oil line come off the top of the tank? If so maybe the line isn't into the tank deep enough. So, at 1/2 at tank the line stars sucking air not oil. I've seen this quite a few times.
    pecmsg Member Posts: 7,064
    After you bleed it, it runs normally?
