Thermostat change, now furnace won't work
lhalstead
Member Posts: 2
in Gas Heating
Hello, We attempted to change the thermostat to a Nest, learned it was not compatible. Put old thermostat back, appears to be working, clicks as if heating, but thermostat will not kick on.
correction....furnace will not kick on.0
How many wires are going into the thermostat? Are you sure they are hooked up the same as before? (taking a before picture is very very helpful but it might be too late)
This is a hot air furnace, or a water boiler?
Post pics.
Did you disconnect the power at the furnace / boiler?0
- 15.8K Strictly Steam
