Corroded drain valve and pinhole in return pipe
I have a 1987 Burnham 140k btu, 1 pipe system in Brooklyn NY,house built in 1but,
1st question my boiler drain valve has corroded so this year I use the return line drain out to remove water. After removing 2 gal of water which was rusty. So I did it a again with my hose under the water steam started to come out with very rusty water. IS THiS OK TO DO?
2) I had a pin hole leak in the return line today, I patched it with epoxy and screw. Then wrapped a 3inch wide bicycle tube around it and put epoxy on it 2 times. I put 3 clamps on it one over the screw(with less pressure than the clamps at the ends). Do you think this will last until the spring when I can get a plumber to change out the pipe? Can I send you a pic?pipe is over 30 feet long stairs have been built over it wall built over it. How would it be replaced?
3) can I use a plastic drain out valve, to replace my corroded one? I think it came from my old water tank.
aced
No plastic. You're definitely ready for new returns, you're on borrowed time pal. Mad Dog 🐕1
THANKS all! Great site. Ebebratt-ed yes the low water and automated refill are both working. I have a 1/2 gallon of epoxy and i am thinking of painting the whole return line in epoxy reinforced with screening. I can't see how a plumber would replace the whole pipe without ripping up my whole basement. My mom's sewer pipe had a 2 foot crack a decade ago and i fixed it with the reinforced expoy and it has not leaked a dropped since. Per your advise I will pick up a brass drain. Do you think I can keep on cleaning out my system from the return drain and fix the drain valve with brass in the spring. Or is this an ASAP fix. I was thinking to wait for the spring so I could clean out the pigtails, pressure valve at the same time. But if it's ASAP I will do it next week.0
- 50 Industry Classes
