Beckett to replace Riello?
The existing Riello uses a .55 gph nozzle. Does this mean a Beckett would also use that same rating? I have the oil company coming to give me a price and was interested in which Beckett model would be used in a Buderus Logano G115
  • DJD775
    DJD775 Member Posts: 258
    edited January 2024
    The nozzle can and most likely will be different based on the burner chosen but the oil company tech should know the proper setup.
  • Northerners123
    Northerners123 Member Posts: 8
    I read there are AFG and NX Beckett. What’s the difference and how do these perform with a Buderus?
    Steamhead Member Posts: 17,955
    @Northerners123 , which G115 is this? What is the number that comes after the 115?
    Consulting
  • Northerners123
    It’s a 115ws-3
    HVACNUT Member Posts: 6,986
    Why exactly is the Riello being downgraded IMO to a Beckett?
    It doesn't so much matter whats stamped on the nozzle, but the actual firing rate based on nozzle size and pump pressure.
    The F3 Riello is a .55 nozzle @ 185 psi for a .75 GPH input.
    The Beckett AGF and NX both show 150 psi using a .50 or .60 GPH nozzle for .61 or .74 GPH firing rates, respectively.
    What is the problem they are trying to solve? I personally find Becketts easier to work on than Riellos, but either can perform well. I would not advocate changing burners just because the existing one isn't my favorite brand.
    Consulting
  • Northerners123
    They aren’t it’s my own preference to have a burner that any tech can service without me having to second guess if they serviced it correctly. With this riello making noise , if it decides to quit in the middle of the night id prefer to be sure that they will be able to fix it with parts on the truck.
    mrblint
    Jamie Hall Member Posts: 26,348
    A valid concern -- and one reason why we often say that the installer is more important than the brand on the box.
    MikeAmannMaxMercymrblint
    It's 2024. If a residential oil tech doesn't have Riello 40 parts on the truck, they shouldn't have a truck.
    And if they can't handle Riello, they sure won't be able to handle an NX.
    Grallertfueloilrich631
