Boiler ignition parts lifespan
Everything has been working well but they're what came with the unit when I bought the building 3 years ago and have no idea how old they are.
Thanks
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
I can safely tell you that the gas valve and the Baso switch are both over 20 years old, as a matter of fact they could be 40 years old.
EDIT: The date code on that gas valve indicates the valve was manufactured in 1997 some time in October.
The thermocouple may have been changed in the last 10 years and that is a part that does wear out, so having one of those on hand is not a bad idea.
https://www.supplyhouse.com/Resideo-Q390A1061-36-Thermocouple?_br_psugg_q=36+inch+thermocouple
https://www.amazon.com/EZ-FLO-INTERNATIONAL-60036-Eastman-Thermocouple/dp/B00KPEU9AC/ref=sr_1_3?crid=3G5F22UBQTX2C&keywords=thermocouple&qid=1704831183&s=industrial&sprefix=thermocouple,industrial,89&sr=1-3&th=1Edward Young Retired
3 -
Thank you. Will order a 36" coupler to have on hand then.EdTheHeaterMan said:I can safely tell you that the gas valve and the Baso switch are both over 20 years old, as a matter of fact they could be 40 years old. EDIT: The date code on that gas valve indicates the valve was manufactured in 1997 some time in October. The thermocouple may have been changed in the last 10 years and that is a part that does wear out, so having one of those on hand is not a bad idea. https://www.supplyhouse.com/Resideo-Q390A1061-36-Thermocouple?_br_psugg_q=36+inch+thermocouple https://www.amazon.com/EZ-FLO-INTERNATIONAL-60036-Eastman-Thermocouple/dp/B00KPEU9AC/ref=sr_1_3?crid=3G5F22UBQTX2C&keywords=thermocouple&qid=1704831183&s=industrial&sprefix=thermocouple,industrial,89&sr=1-3&th=1Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Can you post more pictures of the entire gas train devices?0
JUGHNE said:Can you post more pictures of the entire gas train devices?
This is an older pic but not much has changed since. This the section you wanted to see?Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
amir12 said:The lifespan of boiler ignition parts can vary depending on factors such as usage, maintenance, and environmental conditions. Common components like spark ignitors, flame sensors, and control modules typically last several years, ranging from 5 to 10 years on average. Regular maintenance, including cleaning and inspection, can extend the lifespan of these parts. However, factors like corrosion or electrical issues may affect their longevity. If ignition components fail or show signs of wear, it's advisable to replace them promptly to ensure the boiler's efficient and safe operation.
It's all working perfectly, what are signs of wear? It's just all just dirty from age.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
I'm not the expert on dating stuff exactly but my guess would be that boiler is from the 50's or 60's.0
Does this have 2 pilots? Is that what the Baso switch is for?0
It does have 2 pilots. I leave them on in the off season as well. The boiler is from the 50s from what I can tell.mattmia2 said:Does this have 2 pilots? Is that what the Baso switch is for?Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
I have a number of rental properties and have spare components for every part of every system. Over 40 years the only unexpected failures I've experienced have been a couple of thermo-couples, a transformer and an electronic low water cutoff.
I do good maintenance, but many controls are over 10 years old. Having spare parts helps me sleep well on cold nights. Now back in the days of burning oil, I spent many nights blowing out oil lines and changing nozzles and filters, but those years are behind me.0 -
Long Beach Ed said:I have a number of rental properties and have spare components for every part of every system. Over 40 years the only unexpected failures I've experienced have been a couple of thermo-couples, a transformer and an electronic low water cutoff. I do good maintenance, but many controls are over 10 years old. Having spare parts helps me sleep well on cold nights. Now back in the days of burning oil, I spent many nights blowing out oil lines and changing nozzles and filters, but those years are behind me.
Really appreciate the feedback. Yes, I've started accumulating the spares and scheduled a local plumber who does combustion check and tune to come and look.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
So, please tell me if I understand this system:
The main gas combo valve has a 1/4 pilot gas line that has a tee installed to a second pilot light.
You light the first pilot in the usual manner. That is holding the magnet on in the gas valve.
The 2nd pilot is spewing gas until you light it.
The 2nd pilot activates the Baso magnet and closes the electric switch which is in series with the gas control safeties.
So if the first pilot fails then all gas is off.
If the 2nd pilot fails then main gas valve will not energize.1 -
Sounds right but I didn't install it but I do see the t on the 1/4" line between the pilots. Last year after I had a local plumbing company do the annual inspection, after they left the pilots wouldn't light up. I called them back and they said the baso button probably needed to be pressed down. I pressed it and everything lit up fine.
I assumed that both pilots were only controlled by a manual valve because that is the age of the equipment but it looks like the pilot does come off the main valve.0
- 167 Indoor-Air Quality
