Zoned STEAM????
Saw this today. Boiler is a large atmospheric Weil Mclain.
    EBEBRATT-Ed Member Posts: 20,141
    It can be zoned but it can greatly affect how the condensate returns. Sometimes you need a boiler feed or condensate pump.
    Long Beach Ed
    mattmia2 Member Posts: 16,645
    You can do it but not like that. There need to be drips at the zone valves to keep condensate from stacking up on the closed valve, especially the vertical one.
    Long Beach Ed
    ethicalpaul Member Posts: 8,726
    If you thought the boiler was oversized before.... :sweat_smile:
    Dave in QCA
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    If that's an LGB model, hopefully they hooked up the 2 stage valve.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,828
    Many zoned systems out there, usually in commercial buildings and churches. It's fun figuring them out and always rewarding to backwards engineer them and find that the dead guys often did everything exactly right.
    Dave in QCA
