Zoned STEAM????
takoateli
Member Posts: 42
Saw this today. Boiler is a large atmospheric Weil Mclain.
If you thought the boiler was oversized before....
See my sight glass boiler videos: https://bit.ly/3sZW1el1 -
If that's an LGB model, hopefully they hooked up the 2 stage valve.Dave in Quad Cities, America
http://grandviewdavenport.com1 -
