Zoned STEAM????
takoateli
Member Posts: 42
Saw this today. Boiler is a large atmospheric Weil Mclain.
If you thought the boiler was oversized before....
If that's an LGB model, hopefully they hooked up the 2 stage valve.Dave in Quad Cities, America
http://grandviewdavenport.com1 -
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
