System 2000 problems
Woody8834
Member Posts: 2
System 2000 oil boiler approx. 8 yrs old - Light flashing on indicator at 140 degree -reset power switch -140 light resets normally - boiler indicates hard faulted - reset- failure on next boiler start - after bleeding system - fuel looks clean -no water -unit starts normally - and runs - this problem is reoccurring - has new fuel pump- cat cell -filter -diagnostic check - on burner -shows cad cell working perfectly - and all systems working normally thanks for any help
Nothing really say. The 140 likely means the burner went into safety. Only an oil tech with the right instruments can solve this mystery. You don't have a service agreement with anyone?0
Oil tech is working on this-I'm just out looking for other ideas since the problem is intermittent0
EK has excellent tech support. And homeowner support... through tech support.pecmsg said:
Has he contacted Tech Support?Woody8834 said:Oil tech is working on this-I'm just out looking for other ideas since the problem is intermittent
You don't necessarily need an EK dealer, but you do need someone who knows oil, and EK will gladly guide the tech, dealer or not.1 -
Woody8834 This sounds like a burner issue. If you have to bleed the fuel in order to get it to fire then it could be caused by high vacuum in the fuel lines or an air leak. If your service company would like some assistance troubleshooting the system, they can contact our tech support line at 908-735-2066John Ringel Energy Kinetics2
