System 2000 problems
Woody8834
Woody8834 Member Posts: 2
edited January 2024 in Oil Heating
System 2000 oil boiler approx. 8 yrs old - Light flashing on indicator at 140 degree -reset power switch -140 light resets normally - boiler indicates hard faulted - reset- failure on next boiler start - after bleeding system - fuel looks clean -no water -unit starts normally - and runs - this problem is reoccurring - has new fuel pump- cat cell -filter -diagnostic check - on burner -shows cad cell working perfectly - and all systems working normally thanks for any help
    HVACNUT Member Posts: 7,526
    Nothing really say. The 140 likely means the burner went into safety. Only an oil tech with the right instruments can solve this mystery. You don't have a service agreement with anyone?
  • Woody8834
    Oil tech is working on this-I'm just out looking for other ideas since the problem is intermittent
    pecmsg Member Posts: 7,281
    Has he contacted Tech Support?
    EK has excellent tech support. And homeowner support... through tech support.
    You don't necessarily need an EK dealer, but you do need someone who knows oil, and EK will gladly guide the tech, dealer or not.
    MikeAmann
  • jringel
    jringel Member Posts: 52
    Woody8834 This sounds like a burner issue. If you have to bleed the fuel in order to get it to fire then it could be caused by high vacuum in the fuel lines or an air leak. If your service company would like some assistance troubleshooting the system, they can contact our tech support line at 908-735-2066
    John Ringel Energy Kinetics
    MikeAmannszwedj
