Circular radiator
miwyant
Member Posts: 1
Customer has a circular radiator, only getting hot 1/4 of the way around. There are 1/4" copper tubing jumpers between section in two spots. Boiler pressure is about 4-5 psi .
Tried pulling guts out of supply valve, removed cap from steam trap - with steam flowing in I get nothing coming into trap after several minutes.
Anyone seen these or had issues like this
Thanks for any help
Mike
Thanks for any help
Mike
Well, how about some info about the steam system?
You say it has a trap which indicates it’s a two pipe system. Can you post some pics of the boiler and near piping, system vents and traps?
4-5 psi is way too high, it should be no more than 2 psi, maybe even less depending upon the type of system.Bob Boan
@miwyant , how about some pics?All Steamed Up, Inc.
Consulting1
- 50 Industry Classes
