Install of the Year!
I'm amazed that someone would put their name on this.All Steamed Up, Inc.
Consulting2 -
There where several someones tagging it0
The wires holding up the 1/2" feed line is a nice touch.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
They didn't know any better..and If they did, they were doing it THEIR way regardless. Mad Dog 🐕0
Looks like it is.
And another upside down strainer. Thats the second one today!0 -
Like @Mad Dog_2 said if they knew any better, they wouldn't have put their name on it. They were proud of it.1
Fortunately this one's a y-pattern check valverealliveplumber said:Looks like it is.
Cool house, even had some old Window Seat regulators and handles..Oddly enough, about a mile away was this, a Redflash, converted to NG, that was still feeding a 1 pipe system….just chugging away…still had the dampers attached to an old Dunham Damper Regulator. A couple Paul fittings as well. A tad inefficient to say the least,one 3in tapping straight up about 36in to the main…
I've seen Dunham systems where they used Dunham's Paul vents as crossover traps.All Steamed Up, Inc.
Consulting0 -
As crossovers? On a vapor system? Wow, can they move enough air to get the system to work properly? A case of “any port in a storm” if nothing else was available?0
I do not see the steam safety relief valve in the picture but I hope that there is one.0
Those are likely service stickers not install stickers?
Doesn't matter, no way we will know unless you want to call those numbers. No one puts stickers assuming it will be blasted on the internet, it's for the homeowner to know who to call current/future.
I judge installers and servers on how they place stickers.
If they place it randomly and crooked, I automatically assume their work is just as sloppy.
2 -
SteamCoffee said:Out house shopping this week and spotted this, beautiful isn’t she? 1987 install…One way to get familiar something you know nothing about is to ask a really smart person a really stupid question0
You can see the older cast iron fittings, someone redid the near boiler piping in copper.0
Yes, because no pro would ever dare!reggi said:
Were they using copper on steam 37 years ago ? I thought that was a relatively new thing with less Pros in the field..NJ Steam Homeowner.
For what it's worth, I think the minitube steam systems were intended to be plumbed in copper and I think that was from the 1950s.
Clearly, that wire is there to pitch the pipe, to insure the swing check stays closed and will properly back up the double check after it.0
I also noticed some nice Hoffman 75s on the returns. The radiators didnt seem to leave the obligatory water stains under the vents. Btw the house was built in 1928. I did notice some rusty dust on the floor under the boiler, which is centered over a drain.0
I knew I remembered that header from someplace , Frank Gherettys work! The header for a Mills water tube boiler!
@SteanCoffee That is a nice picture of the Mills 350/3500 steam boiler return0
A friend of mine had an Ideal #1 boiler using oil a few years back.SteamCoffee said:Cool house, even had some old Window Seat regulators and handles..Oddly enough, about a mile away was this, a Redflash, converted to NG, that was still feeding a 1 pipe system….just chugging away…still had the dampers attached to an old Dunham Damper Regulator. A couple Paul fittings as well. A tad inefficient to say the least,one 3in tapping straight up about 36in to the main…
It was running roughly 80% efficient according to the printout from his oil guy.
Not bad for a 90 year old boiler. Personally, I felt it was more than efficient enough.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
