Install of the Year!
Out house shopping this week and spotted this, beautiful isn’t she? 1987 install…
WaherMad Dog_2garretjh
    EBEBRATT-Ed Member Posts: 20,141
    For all we know it just might work fine even though not text book piping for sure.
    Mad Dog_2CLamb
  • dko
    dko Member Posts: 669
    Dirty old pail, at least they've been blowin her down!
    Mad Dog_2
    Steamhead Member Posts: 18,453
    I'm amazed that someone would put their name on this.
    Consulting
    Mad Dog_2SteamCoffee
  • Dan_NJ
    Dan_NJ Member Posts: 268
    One of them even tagged it twice - just in case
    dkoSteamCoffeeCLamb
  • SlamDunk
    SlamDunk Member Posts: 1,802
    There where several someones tagging it
  • The wires holding up the 1/2" feed line is a nice touch.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,538
    They didn't know any better..and If they did, they were doing it THEIR way regardless.   Mad Dog 🐕
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,587
    Is that a pressure reducer/feeder on the water line going into the steam boiler??
    realliveplumber
  • realliveplumber
    realliveplumber Member Posts: 354
    Looks like it is.
    And another upside down strainer. Thats the second one today!
    Like @Mad Dog_2 said if they knew any better, they wouldn't have put their name on it. They were proud of it.
  • dko
    Looks like it is.
    Fortunately this one's a y-pattern check valve
  • SteamCoffee
    SteamCoffee Member Posts: 123
    Cool house, even had some old Window Seat regulators and handles..Oddly enough, about a mile away was this, a Redflash, converted to NG, that was still feeding a 1 pipe system….just chugging away…still had the dampers attached to an old Dunham Damper Regulator. A couple Paul fittings as well. A tad inefficient to say the least,one 3in tapping straight up about 36in to the main…
    I've seen Dunham systems where they used Dunham's Paul vents as crossover traps.
    Consulting
  • SteamCoffee
    As crossovers? On a vapor system? Wow, can they move enough air to get the system to work properly? A case of “any port in a storm” if nothing else was available?
  • retiredguy
    retiredguy Member Posts: 1,090
    I do not see the steam safety relief valve in the picture but I hope that there is one.
  • Grallert
    Grallert Member Posts: 1,111
    Those are likely service stickers not install stickers?
  • dko
    Doesn't matter, no way we will know unless you want to call those numbers. No one puts stickers assuming it will be blasted on the internet, it's for the homeowner to know who to call current/future.
    I judge installers and servers on how they place stickers.
    If they place it randomly and crooked, I automatically assume their work is just as sloppy. :o
    Dan_NJSteamCoffee
  • reggi
    reggi Member Posts: 537
    Were they using copper on steam 37 years ago ? I thought that was a relatively new thing with less Pros in the field..
    One way to get familiar something you know nothing about is to ask a really smart person a really stupid question
  • dko
    You can see the older cast iron fittings, someone redid the near boiler piping in copper.
    ethicalpaul Member Posts: 8,726
    edited January 2024
    Yes, because no pro would ever dare! :sweat_smile:
    GGross
  • ChrisJ
    ChrisJ Member Posts: 17,346
    For what it's worth, I think the minitube steam systems were intended to be plumbed in copper and I think that was from the 1950s.
  • Teemok
    Teemok Member, Email Confirmation Posts: 757
    Clearly, that wire is there to pitch the pipe, to insure the swing check stays closed and will properly back up the double check after it.
  • realliveplumber
    dko said:
    Looks like it is.
    Couldn't see the bolt on my tiny screen,
  • SteamCoffee
    I also noticed some nice Hoffman 75s on the returns. The radiators didnt seem to leave the obligatory water stains under the vents. Btw the house was built in 1928. I did notice some rusty dust on the floor under the boiler, which is centered over a drain.
  • SteamCoffee
    I knew I remembered that header from someplace , Frank Gherettys work! The header for a Mills water tube boiler!
  • retiredguy
    @SteanCoffee That is a nice picture of the Mills 350/3500 steam boiler return
  • ChrisJ
    edited January 2024
    A friend of mine had an Ideal #1 boiler using oil a few years back.
    It was running roughly 80% efficient according to the printout from his oil guy.
    Not bad for a 90 year old boiler. Personally, I felt it was more than efficient enough.
    mattmia2 Member Posts: 16,645
    this is only january. i assume the install of last year was one of the gravity hot water systems someone tried to install a steam boiler on.
    reggi
