Honeywell PA404A For Sale
I replaced my old pressuretrol with a vaporstat. The old pressuretrol needs to be calibrated. When I bench tested it, i found that it would actually cut in around 5.5 psi. The differential seems to be working correctly. Asking $100
  • Big Ed_4
    Big Ed_4 Member Posts: 3,412
    The pressure is set too high :smile:
    EdTheHeaterMan Member Posts: 11,759
    Really... To high for what? The air pressure in the box? It isn't set for anything because it's not connected to anything. Besides there is no wires on the screws. without wires, the box air pressure won't matter. Everyone knows that in order for that control to jump out of the box to install itself, you need wires connected!
    Dah!
    Steam_Guy56
  • Steam_Guy56
    Steam_Guy56 Member Posts: 18
    Feel free to make an offer if you think $100 is too high.
