Honeywell PA404A For Sale
Steam_Guy56
Member Posts: 18
I replaced my old pressuretrol with a vaporstat. The old pressuretrol needs to be calibrated. When I bench tested it, i found that it would actually cut in around 5.5 psi. The differential seems to be working correctly. Asking $1000
The pressure is set too high
Really... To high for what? The air pressure in the box? It isn't set for anything because it's not connected to anything. Besides there is no wires on the screws. without wires, the box air pressure won't matter. Everyone knows that in order for that control to jump out of the box to install itself, you need wires connected!Big Ed_4 said:The pressure is set too high
Dah!
1 -
Feel free to make an offer if you think $100 is too high.Steam_Guy56 said:
I replaced my old pressuretrol with a vaporstat. The old pressuretrol needs to be calibrated. When I bench tested it, i found that it would actually cut in around 5.5 psi. The differential seems to be working correctly. Asking $1001
