The case of the cold radiator, this weeks case
RayWohlfarth
RayWohlfarth Member Posts: 1,979
This case is probably an easy one. The room was colder than the other. When we arrived, the radiator was covered in a steel radiator cover. Pulling the cover away from the wall, we found the radiator was indeed warm. The heat just didnt get into the room. This video will talk about how different enclosures affect the heat output of a radiator. See you on Friday at 6am
Ray Wohlfarth
Boiler Lessons
