Baseboard constantly warm
HeatingHelp
Administrator Posts: 722
This discussion was created from comments split from: baseboards hot but thermostat disconnected.
So what was the solution to this problem ? I think I have the same problem0
Its best to start a new thread with your issues. Less confusion that way.XxvelozzxX said:So what was the solution to this problem ? I think I have the same problem
@XxvelozzxX, welcome to Heating Help! I've created a new discussion for you here to prevent confusion.
Thanks @pecmsg.President
HeatingHelp.com0 -
@XxvelozzxX I think you will find the answer if you read and understand the information in this book https://s3.amazonaws.com/s3.supplyhouse.com/product_files/108119-Reference Guide.pdf Starting on the second column of Page9 and ending on Page12. It is all about how to use pumps for zoning in place of zone valves.
So if my pipes still hot way after going on heating mode , that mean the Flo control valve still open .. is that correct ?0
- 50 Industry Classes
