Baseboard constantly warm
HeatingHelp
HeatingHelp Administrator Posts: 723
This discussion was created from comments split from: baseboards hot but thermostat disconnected.
  • XxvelozzxX
    XxvelozzxX Member Posts: 2
    So what was the solution to this problem ? I think I have the same problem
    pecmsg Member Posts: 7,083
    Its best to start a new thread with your issues. Less confusion that way.
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,363
    @XxvelozzxX, welcome to Heating Help! I've created a new discussion for you here to prevent confusion.
    Thanks @pecmsg.
    President
    HeatingHelp.com
    EdTheHeaterMan Member Posts: 12,265
    edited January 2024
    @XxvelozzxX I think you will find the answer if you read and understand the information in this book https://s3.amazonaws.com/s3.supplyhouse.com/product_files/108119-Reference Guide.pdf Starting on the second column of Page9 and ending on Page12. It is all about how to use pumps for zoning in place of zone valves.
  • XxvelozzxX
    So if my pipes still hot way after going on heating mode , that mean the Flo control valve still open .. is that correct ?
