Fuel oil general filter 2a-700a
gator
Member Posts: 26
Hi, so I have a 2a-700a fuel oil filter.
When you clean your house what is one of the items you use?0
Not to worry. The pump is pulling some suction, to be sure -- but nowhere near a 40 psi differential (the absolute maximum it could be is 15 psi). The pump does add pressure as the oil goes through it -- that's what it is supposed to do, but that doesn't affect the intake.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
