Fuel oil general filter 2a-700a
gator
gator Member Posts: 26
edited January 2024 in Oil Heating
Hi, so I have a 2a-700a fuel oil filter.
  • BDR529
    BDR529 Member Posts: 376
    When you clean your house what is one of the items you use?
    Jamie Hall Member Posts: 27,582
    Not to worry. The pump is pulling some suction, to be sure -- but nowhere near a 40 psi differential (the absolute maximum it could be is 15 psi). The pump does add pressure as the oil goes through it -- that's what it is supposed to do, but that doesn't affect the intake.
    gator
