Burnham Alpine 210, fan and swirl plate destroyed, 3 years old
SethYank
Member Posts: 36
Customer has no heat, try to start fan making horrendous noise. Got new fan went to install swirl plates look like someone took a sandblaster to them. Inside gas/air duct looks oxidized. I havent had a chance to read the iom yet but am looking for direction to focus. Possible lead time of 2 weeks for the swirl plate.
the installer used a concentric fitting, wrong?0
I just printed out the IOM and going to read0
The manufacturer most likely says it's okay to use the concentric vent termination, but it's not recommended. It works as designed if installed in an ideal location with no winds. They write the intake and exhaust should be 12" apart both horizontally and vertically when piped separately but then list the concentric vent termination as ok. Makes no sense to me.
- 50 Industry Classes
