Boiler not holding pressure
lisap
Member Posts: 10
Just had a brand new boiler put in a month ago. Not holding pressure. Rep came out and topped off the water. Held for a couple days than down to zero again. Any ideas what the issue is. Base board heaters are heating.
Yes have hot water. When they came out, he just added water . Never purged. Should that be done. If a leak. How do I find leak?
Where is the boiler?
Is the house on a slab, crawlspace, basement?
It is in the lower level of home on slab0
Is this something the installer should need to troubleshoot since just installed brand new0
Yes. The installer should be responsible to find the problem. It may or may not be his responsibility to repair whatever is wrong......It depends on what you bought.
If he used the old expansion tank or water feed valve etc and that wasn't included as new in his quote they you would be responsible for that.
Not holding pressure on a new boiler is seldom a boiler leak. It may be he did not purge the system of air or bleed it properly (that IS his responsibility if he changed the boiler), could be a bad expansion tank or a defective water feed valve. It could be a leak in the system but you ould probably notice water somewhere.
The system should be pressure tight. A hot water system should not need water to be added to it.1 -
Why did you have the boiler replaced?0
I replaced the whole system because the old one was red flagged. Don't see water anywhere. How do they search for slab leak? Sounds like a nightmare as just bought brand new. Old boiler worked fine.0
Dumb question. When they were called out. He saw zero psi. Added water and did nothing else. Should he have done more. Purge?? In your opinion.0
It can take a week or more to get all the air purged out via the systems purger.
When air comes out, water needs to be added somehow. Either manually or by an autofill valve.
You should not need them to come back if you have a fill valve that is working.Bob "hot rod" Rohr
Living the hydronic dream1
