Radiant Heating Between Joists and structural Beam
TorstenCa
Member Posts: 2
Hello,
I am about to start a construction project and I will put radiant’s hoses between the open joists.
My issue is that I will have structural beams between the joists at 2 places.
How do you deal with that, as I think I won’t be able to notch them? Running under the beam?
Thank You!
Thank You!
What material are the joists and beams? Are they sized to be flush on top and bottom? I like setting the beam 1 1/2" lower than the joists and installing small 2x blocks on top of the beams for the hangers to nail to. The tubing can then slide over the top of the beam."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
The Beam will be LVL and the joists pine open joists. Yes they supposed to be flush. I may ask if they are able to leave a space over the beam.0
Get the hole charge for the LVL you are using, they are fairly generous with holes 1-1/2 or less. Two 1/2” pex fit through a 1-1/2” holeBob "hot rod" Rohr
Living the hydronic dream2 -
732-751-1560
Rich McGrath 732-581-38330
