Lochinvar Noble Combustion Analysis
Le John
Member Posts: 250
How is Efficiency calculated in a combustion analysis? The attached low fire combustion analysis shows the efficiency rating as 99.12. How is this being calculated.
The higher efficiency you will achieve with condensing boilers ,is when running on low temperatures . The efficiency curve will drop on higher temperatures .
you need to read this one. https://forum.heatinghelp.com/discussion/195137/why-my-85-efficient-cast-iron-boiler-is-really-only-78-efficient
then follow up with this one:
https://tsi.com/getmedia/02417ee5-cccc-4dc7-80bc-f7f10924d20a/CA-basic-2980175?ext=.pdfEdward Young Retired
It looks like your boiler is tuned for optimal efficiency. The numbers are perfect!
Combustion efficiency numbers that are calculated, advertised by the boiler manufacture or referred to in the energy code are pure fiction. They make folks feel good but have no basis in math or science.
Albert Einstein0 -
Must be running that boiler at a low temperature? If 116F is the flue gas temperature.
The key to mod con high efficiency numbers has to do with return temperature.
Even when they start to run out of condensing mode, they are still efficientBob "hot rod" Rohr
Living the hydronic dream0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
