The case of the non heating steam system, this Friday's case
Boiler Lessons
Two zones? Was it two boilers or was there something crazy like a motorized valve?
My best guess is that there was a steam radiator in the attic that had been disabled for years. When the boys moved up there, they reactivated the radiator (with the valve, or by re-installing a plugged vent, whichever).
But the supply pipe for that radiator was in the wall behind the thermostat, heating it prematurely.NJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el8 -
I think so too.ethicalpaul said:My best guess is that there was a steam radiator in the attic that had been disabled for years. When the boys moved up there, they reactivated the radiator (with the valve, or by re-installing a plugged vent, whichever).
But the supply pipe for that radiator was in the wall behind the thermostat, heating it prematurely.All Steamed Up, Inc.
Consulting3 -
Yup. We had that problem in my condo building when I moved in and took over maintenance. Upstairs units were not getting enough heat. I investigated and found the hot water boilers were short cycling for a number of reasons. The hardest reason to find was that the Tstats were located on the walls right in front of the hot water pipe chases, because the installers used the chases to run the Tstat wires easily.ethicalpaul said:My best guess is that there was a steam radiator in the attic that had been disabled for years. When the boys moved up there, they reactivated the radiator (with the valve, or by re-installing a plugged vent, whichever).
The hot water risers were heating the walls right behind the Tstats, causing short cycling. I moved the Tstats, fixed the other issues, and problem solved.1 -
We have had at least 4 steam systems not heating this week.
But I also think the risers for the attic are behind the thermostat. So move the t-stat or insulate behind it or slow down the heat in the attic.0 -
The thermostat is in a dead air zone. Any heat generated in the common space will satisfy the thermostat, regardless of the condition of the bedrooms. Kids rooms in the attic will have closed doors always.
Is there a radiator in every room with a door?0 -
I hope Ray's OK!!!
Sorry everyone Had a routine medical test and they wouldn't let me have my cell. All is well. I thought for sure I would stump you on this. @ethicalpaul got it first. There was a steam pipe behind the thermostat that went to the attic. They kept it valved off before the boys moved there. Here is the link
https://youtube.com/watch?v=Bn9wCCs8ZE8
Ray Wohlfarth
Boiler Lessons3 -
I knew something had to be up! Glad you're OK, Ray!
See my sight glass boiler videos: https://bit.ly/3sZW1el6 -
I guess @RayWohlfarth has never leaned on a wall in a commercial building and noticed it was warm.0
Thanks @ethicalpaul
@mattmia2 I have This was in a residence and never thought of the steam pipe going to the third floor I learn something new all the time in this tradeRay Wohlfarth
Boiler Lessons4 -
I was wondering the same. Any answers?ethicalpaul said:Two zones? Was it two boilers or was there something crazy like a motorized valve?1 -
Should had watch the video before asking. @ethicalpaul got that one too.BritoPlumbing said:
I was wondering the same. Any answers?ethicalpaul said:Two zones? Was it two boilers or was there something crazy like a motorized valve?0 -
It only is a few degrees, I would not go to the trouble of moving the tstat- I would just remount it on an insulated base0
