Radiator cover
saias
Member Posts: 20
What's the trick to removing the cover on this type of radiator?
Sometimes there are clamps and or screws accessible on the inside from the bottom.
You may also be able to pry it open with a screw driver if its not painted shut.0 -
First I would use a flashlight and mirror to see if there are any hidden clamps. If not, break the paint seal around the edges, then pull straight out at the bottom and slide down a half inch or so.—
Bburd0 -
I think on that one, you have to pull the front cover UP before pulling it OUT.bburd said:First I would use a flashlight and mirror to see if there are any hidden clamps. If not, break the paint seal around the edges, then pull straight out at the bottom and slide down a half inch or so.
Consulting1 -
Agree, paint is probably gluing it together so will need to be pulled firm but slow.Steamhead said:First I would use a flashlight and mirror to see if there are any hidden clamps. If not, break the paint seal around the edges, then pull straight out at the bottom and slide down a half inch or so.
I think on that one, you have to pull the front cover UP before pulling it OUT.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
