Radiator cover
saias
saias Member Posts: 20
What's the trick to removing the cover on this type of radiator?
  • Intplm.
    Intplm. Member Posts: 3,081
    Sometimes there are clamps and or screws accessible on the inside from the bottom.
    You may also be able to pry it open with a screw driver if its not painted shut.
  • bburd
    bburd Member Posts: 1,318
    First I would use a flashlight and mirror to see if there are any hidden clamps. If not, break the paint seal around the edges, then pull straight out at the bottom and slide down a half inch or so.
    Bburd
    EBEBRATT-Ed Member Posts: 20,467
    They are all different and there are no Majic tricks. Just investigate and take your time
    Steamhead Member Posts: 18,696
    I think on that one, you have to pull the front cover UP before pulling it OUT.
    Consulting
    guzzinerd
  • guzzinerd
    guzzinerd Member Posts: 461
    Agree, paint is probably gluing it together so will need to be pulled firm but slow.
    Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
  • saias
    Thank you all. It was the paint. It comes out by pulling up and then pull out the bottom.
    PC7060
