PVC or CPVC for a low (below the waterline) return?
bruce_21
bruce_21 Member Posts: 246
My client's steel low return is clogged and rotted, likely because its partly buried in the dirt floor of the basement. Will PVC or CPVC pipe work here?
Mad Dog_2Waher
  • ChrisJ
    ChrisJ Member Posts: 17,271
    Probably, for a while.
    But I wouldn't do it. PVC's glass transition temperature is around 176F. Meaning, it becomes soft.
    Jamie Hall Member Posts: 27,196
    Use copper
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,504
    No way..Copper is the way to go but make sure you have atleast 3/4"  boiler drains on either end.  I like gate valves just above them so you can always power-flush them in the future...Mad Dog 🐕
  • Mad Dog_2
    This is the Mad Dog 🐕 Method. I PREFER gate valves because they are full port AND The Teflon Ring in a Ball Valve does not hold up well over time with 210 plus Temps, but I have used them in a pinch...Mad Dog 🐕
  • ChrisJ
    The issue I've seen with the PTFE ring isn't from heat but seemed to be from debris chewing it up. I had a beautiful 1.5" ball valve on the skim port that even the nice plating on the ball was destroyed.
    My original boiler drains were also ball valves. All of them, or almost all have been replaced. For boiler drains I went back to good old washer type valves and the skim port I just used a brass plug.
    Mad Dog_2
  • bruce_21
    Thanks for your help Mad Dog! Gate valves and copper pipe! She won't like the price but I certainly don't want to have to this twice.
    MikeAmann
  • Waher
    Waher Member Posts: 372
    Plastic pipe won't be able to handle the 180f+ heat of steam condensate. Copper ($) or brass pipes ($$$) below the water line is fine. If you use copper, there must be appropriate galvanic isolation of copper from cast iron (use brass/bronze valves or fittings to avoid connecting copper directly to iron)
