Hard lockout
My Burnham oil burner keeps on going into hard lockout I can reset it and eventually comes back on what could be the problem
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    Did you look up the error code ?
  • STEVEusaPA
    The problem is you keep resetting it. Might want to get a pro in there before you destroy the system or your home.
    Jamie Hall Member Posts: 27,375
    Or to put it another way: it's trying to tell you that there is some serious problem with the burner or its controls. Resetting doesn't fix the problem. You need someone who can fix it.
