Hard lockout
Robertmilton
Member Posts: 1
in Oil Heating
My Burnham oil burner keeps on going into hard lockout I can reset it and eventually comes back on what could be the problem
Did you look up the error code ?
The problem is you keep resetting it. Might want to get a pro in there before you destroy the system or your home.
Or to put it another way: it's trying to tell you that there is some serious problem with the burner or its controls. Resetting doesn't fix the problem. You need someone who can fix it.Br. Jamie, osb
