That threaded port must be there for some reason?!
hot_rod
hot_rod Member Posts: 27,289
may as well use it
ethicalpaulIntplm.mattmia2ScottSecorSuperTechJUGHNErealliveplumberIronmanGGross
  • Intplm.
    Intplm. Member Posts: 2,988
    Oh No!!!
    mattmia2 Member Posts: 16,404
    This is why some day there will be special fittings that only mate with relief and vent and condensate ports and you have to assemble it with premade nipples and fittings that won't mate to anything else.
    Intplm.
  • JUGHNE
    JUGHNE Member Posts: 11,545
    Hot Rod, how well did the system work?
    Any relief valve issues?
  • RascalOrnery
    RascalOrnery Member Posts: 137
    Same person has snow tires with indentations for stud installation. He's on his way back to the car with the nails...
    EBEBRATT-Ed Member Posts: 20,063
    Idiots
    SuperTech
  • realliveplumber
    realliveplumber Member Posts: 354
    "Ima put the spirovent together......toss me another beer....."
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,065
    Hi, I smell an article here 🤓 We all likely have photos of similarly impressive lack of thought. From plugged relief valves to insulation blanket on a water heater that covers the draft hood. It's just getting the right people to read the article 🤪
    Yours, Larry
    Steamhead Member Posts: 18,393
    Idiots
    Proving once again that you can't fix stupid.
    Consulting
    SuperTech
