So close, and yet so very far…
ratio
Member Posts: 4,229
I just don't know what to say.
If it is working OK, change the orientation of the tee to provide a dirt leg and "let a sleeping dog lay" as we say, unless some code enforcement officer complains. If there is something I do not see, please explain.0
It's either,
"I didn't know"
or
"I'll save a few bucks, I won't be around when it fails anyway."
Not that either is any better than the other.0 -
It's almost certainly working ok.
All that material looks to be existing & the labor was identical, so saving a buck isn't likely, that makes the choices "I didn't know", "I didn't notice", or "I didn't care".
Probably too close to the roof for the drip.
Not supposed to put a drip outside or anyplace it can freeze but that isn't really a drip. I don't see anything wrong with it unless the rusty gas pipe should be cleaned and painted.
Now, if the gas pipe happens to be piped to the condensate drain that is a whole nother issue.0 -
It was the drip. Now, I guess it's just a funny-shaped 90°. They're commonly installed outside around here (not sayin' it's right).EBEBRATT-Ed said:Not supposed to put a drip outside or anyplace it can freeze but that isn't really a drip. I don't see anything wrong with it unless the rusty gas pipe should be cleaned and painted.
Funny you should mention that...EBEBRATT-Ed said:Now, if the gas pipe happens to be piped to the condensate drain that is a whole nother issue.
It was red-tagged because the plumber couldn't get it to hold.
I guess it was just overflowing the pan or something.
Ran out of elbows late on a Friday afternoon.0
- 50 Industry Classes
