So close, and yet so very far…
ratio
ratio Member Posts: 4,229
I just don't know what to say.
  • retiredguy
    retiredguy Member Posts: 1,090
    If it is working OK, change the orientation of the tee to provide a dirt leg and "let a sleeping dog lay" as we say, unless some code enforcement officer complains. If there is something I do not see, please explain.
  • dko
    dko Member Posts: 669
    It's either,
    "I didn't know"
    or
    "I'll save a few bucks, I won't be around when it fails anyway."
    Not that either is any better than the other.
  • ratio
    It's almost certainly working ok.
    All that material looks to be existing & the labor was identical, so saving a buck isn't likely, that makes the choices "I didn't know", "I didn't notice", or "I didn't care".
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,587
    It's all Dan's fault. Dan always says to avoid bullhead T's. Guy probably took one of Dan's steam seminars.
    PC7060
  • STEVEusaPA
    Probably too close to the roof for the drip.
    EBEBRATT-Ed Member Posts: 20,150
    Not supposed to put a drip outside or anyplace it can freeze but that isn't really a drip. I don't see anything wrong with it unless the rusty gas pipe should be cleaned and painted.
    Now, if the gas pipe happens to be piped to the condensate drain that is a whole nother issue.
  • ratio
    It was the drip. Now, I guess it's just a funny-shaped 90°. They're commonly installed outside around here (not sayin' it's right).
    Funny you should mention that...
    It was red-tagged because the plumber couldn't get it to hold.
    I guess it was just overflowing the pan or something.
  • JUGHNE
    JUGHNE Member Posts: 11,547
    I used to think that those "Mr. Obvious" tags such as connect gas here...connect power here...this is a drain etc were pretty lame.
    But time has shown they are needed.
    ratio
  • Intplm.
    Intplm. Member Posts: 3,005
    Ran out of elbows late on a Friday afternoon.
