Flooring guys nicked a pex line, now what
skiereric
Member Posts: 66
1/2" Pex-a line.
No leak or pressure drop.
What is the proper way to fix this?
Get the proper repair coupling and repair from floor below and reconnect clean above the floor0
Any thoughts on using a compression coupling assembly (https://www.heatlink.com/product/heatlink-heating/69005/12-x-12-pex-comp-coupling over a press assembly in this use case?0
skiereric said:Any thoughts on using a compression coupling assembly (https://www.heatlink.com/product/heatlink-heating/69005/12-x-12-pex-comp-coupling) over a press assembly in this use case?Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
Whoops fixed my original link - https://www.heatlink.com/sites/default/files/Info Sheet/L2338-INFO-38-PEX-Tubing-Repair.pdf
Looks like I have a few options
I guess my final question is since the repair will be below the floor, I will need additional pex-a tubing, can I use any brand pex-a o2 barrier or do I need to use the same brand (heatlink pex-a)0 -
If you use a crimp coupling, the top one, or the lower compression coupling, any pex can be used for the repair.
Compression couplings for pex have nylon ferrules inside. The brass ones will cut the tube, so get a plastic "pex" specfic compression coupling, if you go that route.
If you have any slack, you just need one coupling? Cut 1/4" on either side of the nick.
the coupling takes up some distance.Bob "hot rod" Rohr
Living the hydronic dream0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
