Which way is on
How can I tell which way is on and off on an old valve with no markings
Mad Dog_2
    HVACNUT Member Posts: 7,237
    What does it say under the handle?
    Jamie Hall Member Posts: 26,846
    Unless it is really truly weird, clockwise will close it down -- but maybe not off. That looks like a throttling valve, not a stop valve.
    Mad Dog_2Intplm.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Yes, it’s a throttling valve. Those holes probably indicate levels of heat, typically, each space equals 10 square feet of EDR. Turning it clockwise should close it.
    Retired and loving it.
    mattmia2Intplm.
    EBEBRATT-Ed Member Posts: 19,611
    Looks like it says "ON" under the handle.
    mattmia2 Member Posts: 15,639
    Oh and there is a screw in the back or something like that that lets you move the stop on the right to a different hole so you can set it to match the emitter so it doesn't put steam in the returns?
